sambo
Stuck abs sensor.....arrgghhh!
Just tryed changing my stub axle, all unbolted and came off apart from stuborn abs sensor which is stuck within rusty stub axle! Any advice how to remove it? I'v cleaned it as much as poss and soaked it in wd40. Can i try gently knocking it out? Thanks
I had to burn mine out with a blowtorch. The stub axle had corroded inside the mounting hole & the sensor was stuck solid.
