20v turbo 0 Posted November 22, 2004 right guys for those of you out there who have do it is there anything i should whatch out for,any tips or info would be appreciared 8),plan to do over crimbo hols :wink: if i get a chance. Quote Share this post Link to post Share on other sites
biggerbigben 0 Posted November 22, 2004 hummm, I'll list off a few problem area.... Need to make a bracket from transfer box to engine block, need to weld prop shaft brackets in the right place - important, brake bias valve prob needed as 4wd one is crap, need mk1 golf Gti suspension at the rear as corrado one is too long, if your replacing the bearings on the rear then watch out as there are a few different srts, and therefore different sizes, CV's are golf gti 100mm ones, make sure you have all the standard mounts before you start, they take months to order from Germany if you need them!, All in all it all fits up ok, if I can remember anymore I'll let you know, good luck! Ben Quote Share this post Link to post Share on other sites
PhatVR6 0 Posted November 24, 2004 I'll be doing mine over xmas too. I'll keep you all updated with pics. Quote Share this post Link to post Share on other sites
Jim 2 Posted November 24, 2004 Gawd.. these 4WD Corrado's are becoming soooo common ;) Quote Share this post Link to post Share on other sites
daves16v 1 Posted November 24, 2004 If anyone doing this conversion needs any fabricated parts just giz a shout. Dave Quote Share this post Link to post Share on other sites
