chance
dashboard lights?
This evening i started my corrado and noticed there are no lights on the dashboard. Everything else works fine, blinker lights, brake... Everything is ok, only when i turn my lights on, dasboard is still in dark... maybe a relay problem? can anyone post some suggestions where to take a first look at?
thanks in advance....
:cuckoo:
p.s. lights are out only on speedometer and gauges... i have lighst on switch for lights
1 Headlight Left, Terminal 56A 10 199
2 Headlight Right, Terminal 56A 10 204
3 Instrument Panel Light Dimmer Switch 10 247
4 Rear Window Wiper Motor 15 280
5 Windshield Wiper Motor 15 284
6 Fresh Air Blower Switch 20 23
7 Brake/Tail Lights, Right 10 235
8 Brake/Tail Lights, Left 10 228
9 Rear Window Defogger Switch 20 270
10 Open
11 Headlight Left, Terminal 56B 10 199
12 Headlight Right, Terminal 56B 10 204
13 Horn 15 33
14 Back-up Light Switch, Washer Nozzle Heater 10 262
15 Crankcase Ventilation Heating Element 10 97
16 Voltmeter, Engine Oil Pressure Gauge 15 173
17 Emergency Flashers Switch 10 215
18 HO2 S (Heated Oxygen Sensor) Control 20 53
19 Coolant FC (Fan Control) Thermoswitch 30 31
20 Brake Light Switch 10 233
21 Cigarette Lighter 15 170
22 Radio 10 296
fuse 3?
yup, fuse 3 or the contacts on the dimmer switch have given up and need some cleaning and re-adjusting (bending so that they touch the resistive coil again! ;) )
Do the lights in ALL of the switches still work, or is it ALL dash illumination that's gone? (ignore the headlamp switch, as it's not on the dimmer circuit! ;) )
You haven't accidently turned them off using the dimmer(next to headlight switch) have you? I've done that one a few times
LOL! I was going to say that :D
Bugger, I decided to see if this was the cause of my lack of dash illumination and... well I'm half way there. Fuse 3 WAS blown and I've got a new headlight switch. SO, I swapped fuse 3 and it blew as soon as I put the lights on.
Guess this means I've got a short circuit.... Any ideas where to start looking?
Anyone got a wiring diagram for this circuit?
(Incidentally hiding the fuse box behind that pocket/tray made it extra hard to find!)
could be.... this wouldn't catch my mind, thanks for suggestion
have to check it all,
i will let you know the results
still i believe it is the fuse, just didn't had time to solve it out
this was the issue....
:oops:
I've fixed mine too!!!
I've learnt the value of a quality fuse.
The fuses in my corrado are all the same brand and are the horseshoe shape type where there is no plastic accross the top. I blew 4 of those testing the circuit so I put in one from RS components where it's the normal whole rectangle of plastic like Halfords do. Didn't blow and the lights work for the first time in 6 weeks!
I would have taken apart the whole dash on Saturday if I hadn't tried a different make of fuse!
BUGGER, it was all fine for the drive home from work. Then later I went over a speedbump and the dash lights went out again!
Any ideas where the fault will be?
