Storm
Brake and clutch fluid
Don't use DOT5!!!!!!!!!!!!!!!!!!!!!!!!!!! - its silicone based! :shock:
Use DOT 4 (standard) or 5.1
2 litres from VAG / GSF or the 5.1 from Halfords!
Thanks, that was close :oops: luckily ECP have just opened up 2 miles away, I'll pop in there tomorrow and get some.
The Halfords Perfomance brake fluic (dot5.1) is the cheapest DOT5.1 I've found as yet and is very good... (which suprises me to say it!) It's in a black tub with orange writing on it and was about £12 per litre IIRC... 8)
As Supercharged says, DON'T use DOT5 as it's silicone based and willl kill your brake and clutch seals! :shock:
It's better to pressure bleed the system rather than doing it manually. This way you don't push the cylinders past the master cylinder past it's normal range of movement. If you have a high mileage car the piston is likely to have very slightly worn its own path in the cylinder which the seals have "accomodated". By pushing the cylinder beyond this you risk nicking the seals slightly and losing pressure when you brake.
