nephilim 0 Posted December 4, 2004 Hello everyone, Just been trying to change the bulbs on my "new" Corrado and it seems that it's not the 5 minutes job I was hoping it would be. Managed to change the passenger side bulb OK but I cannot easily remove the drivers side bulb due to the air intake and housing beneath it. Am I missing something? Car is a 93 VR6. Also, was wondering if there was a way of raising the spoiler on the car when parked in order to clean up it properly? Cheers, Dave. Quote Share this post Link to post Share on other sites
Guest Posted December 4, 2004 Can help with the spoiler question, with ignition on press the rocker switch on lower dashboard near your right knee - this allows you to raise and lower spoiler manually Quote Share this post Link to post Share on other sites
Tekara 0 Posted December 4, 2004 You need to take the headlight off the car. Undo the two screws on the top edge of the light, then loosen the one in the middle. To get to it you will need a long screw driver to reach through the hole in the slam panel. Then unclip the cable connector from the back. Change bulb and repeat in reverse When removing be careful not to drop the headlamp. Quote Share this post Link to post Share on other sites
