lizzie 0 Posted December 6, 2004 My 8 year old Storm battery gave up the ghost the other day and after disconnecting to charge up the battery overnight to see if it would do any good, I found that my alarm now comes on when I try to start the engine. It's a VW Logic 900 (dealer fitted) (which may or may not be the same as a Clifford Arrow 2 as I seem to have papers relating to both which I think came with the car, bought 2nd hand). It's been suggested that I remove the 5amp fuse for a while so that the alarm resets, but I can't even find the fuse! Any suggestions gratefully welcomed, as the alternative seems to be nearly £100 to get the alarm people to sort it out. Thanks Lizzie Quote Share this post Link to post Share on other sites
h100vw 0 Posted December 6, 2004 Try disconnecting the battery again. Gavin Quote Share this post Link to post Share on other sites
joebloggsVR69 0 Posted December 6, 2004 I've got a Logic900. Get it jump started to make sure it is the battery that's causing the problems and not something else. I had similar problems 2 weeks ago :wink: Quote Share this post Link to post Share on other sites
Reggit 0 Posted December 7, 2004 Sounds like the battery has died. Think you need a new one. The alarm coming on when you try and start the car is usually a classic sign of this. Quote Share this post Link to post Share on other sites
