W3RKD 0 Posted June 5, 2003 anyone getting more than this ?? from there glader.. :lol: Quote Share this post Link to post Share on other sites
leew 0 Posted June 5, 2003 I got to 14.5psi and then had to back off as I was on the wrong side of the road with another car coming at me :shock: Its a good job these cars handle so well :D PS. Darren your up early :shock: Quote Share this post Link to post Share on other sites
Toby 0 Posted June 5, 2003 I have seen 18 or 19psi a few times when giving it some really big licks!!! But generally I see 15ish on spirited driving..... Quote Share this post Link to post Share on other sites
CaiosG60 PWR 0 Posted June 5, 2003 Havn't got a boost gage. So not idea! Quote Share this post Link to post Share on other sites
G60Jet 1 Posted June 5, 2003 14psi on a cool morning here!! i.e before the sun comes up Quote Share this post Link to post Share on other sites
W3RKD 0 Posted June 5, 2003 well just to let you guys know that over the maf cant take more than 1 bar 14.5 psi.. so i will let you draw your own conclusions to that one.. :lol: Quote Share this post Link to post Share on other sites
W3RKD 0 Posted June 5, 2003 borrowed this from vortex as an examlple for you guys ... Keep in mind a honda with can make 300hp with 10psi, so psi is not the be-all end-all means of making power.. Its just an example of how much (lack of) flow you have in a motor. In theory the less boost you can run with more flow will make everything better, as with boost comes heat. 20psi of hot air versus 10psi of cool air can equal the same mass density of air. Of course cranking up the boost is the cheap way out, i do it myself, but you can make lots more efficient power with FLOW. The expensive way. so there you go the more boost you have the worst flow you have got .. ie a better cam will give you lower boost hence more flow ! Quote Share this post Link to post Share on other sites
G60 0 Posted June 5, 2003 apparently the newer SNS chips 'guess' at what the boost is if its over 14.5psi as the build rate is linear.. still haven't got a solid answer from them yet for this one if my chip can handle it or not. sam told me the only way to check to make sure its setup correctly is a dyno run. still waiting to hear what danny has to say about it. Quote Share this post Link to post Share on other sites
G60 0 Posted June 5, 2003 here's a thread on the vortex if anyone is interested http://forums.vwvortex.com/zerothread?id=874853 and the thread about my stage 5-5 chip and what it can handle http://forums.vwvortex.com/zerothread?id=871237 Quote Share this post Link to post Share on other sites
RACK 0 Posted June 5, 2003 Just after having my charger rebuilt to a JBS Stage 5 spec, I ran it in and then took it back up and had it boost checked. I got told it was pulling nearly 2bar in third gear :evil: . I've got a 68mm pulley on it? Plus anyone got any ideas how and where's best to fit a boost guage just so I can keep tabs on me G-Lader?? Quote Share this post Link to post Share on other sites
G60 0 Posted June 5, 2003 2bar eh? you're making 29psi with a 68mm pulley? lol! :lol: think they're feedin ya a line of shit man..or you to us. Quote Share this post Link to post Share on other sites
W3RKD 0 Posted June 5, 2003 RACK said: Just after having my charger rebuilt to a JBS Stage 5 spec, I ran it in and then took it back up and had it boost checked. I got told it was pulling nearly 2bar in third gear :evil: . I've got a 68mm pulley on it? Plus anyone got any ideas how and where's best to fit a boost guage just so I can keep tabs on me G-Lader?? noway could any glader ever produce this amount of boost/cfm i think somones having a laugh here :lol: :lol: Quote Share this post Link to post Share on other sites
W3RKD 0 Posted June 5, 2003 who is JBS do you mean jabbasport ? they dont do a stage 5 do they ? i though they only did an r1 i though the only people doing a stage5 was pd-m cos we didnt want to call it r1 of rs of somthing like that ... Quote Share this post Link to post Share on other sites
LowG 0 Posted June 5, 2003 2 bar :shock: :shock: ahhhem NO WAY 8) Quote Share this post Link to post Share on other sites
RACK 0 Posted June 6, 2003 Ok then people must be my mistake :oops: I ment to put 1 bar but my finger slipped and I've only just been able to log back on. JBS are a VW company in Chesterfield and are a top set of blokes. They helped me out with my charger when i couldn't get one from anywhere. I think they're stage 5 is about the same as a uprated Jabba one. It's all gasflowed and internally ported. Once again I'm saying sorry sheepishly. But atleast you had something to talk about :D Quote Share this post Link to post Share on other sites
RACK 0 Posted June 6, 2003 Seen as you've crucified me now for making my mistake. Is there anything on the forum about fitting a boost guage so that I can avoid a possible public linching again by getting a true boost reading :oops: I've only been a member for a couple of days. P.S. Once again thanks John at P.D. Motorsport for the bottom radiator hose. The cheque should be with you shortly. Quote Share this post Link to post Share on other sites
LowG 0 Posted June 6, 2003 all you need for a boost gauge is some vacume pipe and a T joint,i presume you get these with the gauge. Take out the instrument cluster and you see a boost pipe there that goes to the mfa,cut it fit the T joint use teflon tape to seal any boost leaks and route the piping to where you need to fit he gauge. Quote Share this post Link to post Share on other sites
RACK 0 Posted June 6, 2003 Cheers for that. I'll get it sorted asap, to prevent further embarressment. :D Quote Share this post Link to post Share on other sites
