mrbeige 0 Posted December 7, 2004 Just ordered some lowered spring caps from Venom, do I need anything else to fit these? Fitted Koni TA's and H&R srpings a while ago, but didn't replace any other suspension components. Cheers Quote Share this post Link to post Share on other sites
Kevin Bacon 5 Posted December 7, 2004 Nope, they're just a direct replacement for the standard top plate. Some MK4 front bumpstops are a good match with H&Rs and Konis too as they're shorter than the standard ones. If my VR is anything to go by, you'll also need to drop the rear TAs down 2 detents to level the ride off - otherwise you get a slight nose down stance when the tank is empty. As most VRs sit slightly lower on the offside rear, I've actually gone down two notches on the nearside rear and 1 notch on the offside and it sits absolutely perfectly now :lol: Quote Share this post Link to post Share on other sites
mrbeige 0 Posted December 7, 2004 Mine sits higher at the front at the mo, which is why I've ordered them. Thanks for the info kevhaywire. Might have to get the bump stops. Any idea how much they are? Quote Share this post Link to post Share on other sites
Kevin Bacon 5 Posted December 7, 2004 A few quid each IIRC.... Quote Share this post Link to post Share on other sites
mrbeige 0 Posted December 7, 2004 Cheers mon :D Quote Share this post Link to post Share on other sites
