Furkz
Wheels and Arches
can anyone tell me if 17x8 rims will fit on my car without arch mods
should be et 35
60mm drop not coils
Thanks
I've got 17X8's on mine (et 35) and you'll definitely need coilovers as the wheels will foul the strut. Will probably need a spacer as well.
17x8 with 215 section tyres on mine too and normal mcpherson struts. 40-45mm drop.
My arches are standard and the only catching I get is on the nearside rear over big bumps, but only with weight in the back. 205 tyres will solve that though.
Think there are some photos in the members area but roughly speaking you can get a finger between the top of the trye and arch. As kev mentioned I run 205's and only get rubbing when hacking it two up, over bumps and the like. I have had to users spacers though to space the inside on the tyre wall away from the coilover platforms.
