boab
Samco hoses for a 16v
does anyone know if samco hoses will fit a 16v?? been looking around on neet and cant see any for it, just g60, will these fit?? id really like to give the engine bay a bit of colour, plus thats another shitty black plastic pipe burst on me
has no one diy a set of these into there car?
Golf 2 16v set will fit apart from 2 hoses (i.e. you can use 5 of 7)
You will then need to buy lengths of hose and reducers and elbows from samco if you want to do everything.
Golf set is a good start though.
David.
do u know which two dont fit by any chance?
curved hose from bottom of expansion tank to metal water pipe and pipe to heater matrix I think. The top and bottom rad hose, 3 way hose, small link hose from pipe to pump and curly hose from pipe to heat exchanger all fit fine.
A 1.5m length of 8mm bore samco hose will go from expansion tank to top of rad, about 10 quid a metre.
David.
