m1cah 0 Posted December 17, 2004 Anyone know where I can find something called the enursa switch on a c vr6 on the M, apparently cuts off your ECU or is used to reset it. There's no power going through to injectors suspected ECU fault following a helpfull AA bloke who bridged my ECU relay, fix one problem but now suspect he's screwed my ECU. Quote Share this post Link to post Share on other sites
Supercharged 2 Posted December 17, 2004 AFAIK you need to disconect the battery for 15 mins to reset it (or just unplug the connector to it) Quote Share this post Link to post Share on other sites
m1cah 0 Posted December 17, 2004 Will try that but have been told all cars have this switch hidden somewhere and it normally kicks in following a bang (although I've nothad a bang) will try this anyways Quote Share this post Link to post Share on other sites
dr_mat 0 Posted December 17, 2004 There is a fuel cut-off that might be triggered in an accident, but there's no ECU reset switch (that I'm aware of). Not sure where the fuel cut-off is though, I think it's around the rear end of the car, near the fuel filter? Quote Share this post Link to post Share on other sites
m1cah 0 Posted December 17, 2004 think that might be what I'm looking for Quote Share this post Link to post Share on other sites
m1cah 0 Posted December 18, 2004 anyone got any ideas where this 'fuel cut off' is located, have spoken with VW who are telling me they don't have one and its part of the ECU but this one of the guys in the parts dept an he did seem that he knew much. I've also been talkin to the one of the guys at vdubs and they reackon that the later models do have them but wasn't sure where at. With mine being one of the later models I need to check this before replacing ECU Quote Share this post Link to post Share on other sites
h100vw 0 Posted December 18, 2004 I have been around dubs for well over ten years and I have never heard of a Corrado/MK2/MK3 with an 'inertia switch' fitted. The fuel is cut off by the fuel pump relay, the feed for this is only present when the engine is rotating. If the engine stalls then the fuel pump stops running. There is likely to be an ECU relay, which if duff will stop the ECU completely. It could be that the output stage for the injectors in the ECU has blown.? There are other things like the crank position sensor which will stop the injectors firing. Do you get any sparks? That would tell you if the ECU is OKish. Gavin Quote Share this post Link to post Share on other sites
m1cah 0 Posted December 19, 2004 sparks are fine Quote Share this post Link to post Share on other sites
exturbo2003 0 Posted December 19, 2004 there is not a inertia switch on your car pins 2,3,4,24,25,26 are the switcing wires from the ecu for the injectors (12v at rest ign on switching earth under cranking .3-1.5v ac, if you got a good meter if not get a noid light tester from lucas or draper, or a led to plug into the injecter plug, and when cranking the led will flash if its switching) pin 23 is the 12vfor the injectors main relay supplies the voltage pin 28,54,38 = 12v pins 1,7,55,56 = earth 12v= battery voltage with a tolerence of .5v drop hope this helps Quote Share this post Link to post Share on other sites
