samm_cvr6 0 Posted December 18, 2004 Ok, I want to make sure everything is in order, was thinking 1)Chains 2)Brakes 3)Suspension and bump stops/bushes 4)fluids-clutch/gearbox etc Anything else I should make sure they check? The place I am taking it have been very lenient in the past with passing but I want to make sure the car is running well for my benefit and seeing as I'm not driving a disposable jobbie anymore. Ta. Quote Share this post Link to post Share on other sites
andycowuk 0 Posted December 18, 2004 all lights inc headlamp aim rubber boots on suspension and steering joints and cv joints rear break bias adjuster door handles all exhaust hangers in reasonable cond. these are things that have tripped up the rocco and golf when i have had them tested in the past Quote Share this post Link to post Share on other sites
Heardy 0 Posted December 18, 2004 Check all steel brake pipe's for corrosion and also check flexible brake pipe steel end's for corrosion and also pipe's for bulge's. If there is any corrosion give them a clean with a wire brush and either grease them up. Also check tyre tread depth's,wiper's washer's horn all work Quote Share this post Link to post Share on other sites
