dubster82
Mirrors
A Guy i know has just bought a 150KMiles VR and is wondering why The mirrors dont work.
Any particular reason for this? Apparently he has checked all the fuses. Central locking dont work either.
Persume its the pump?
The contacts in the mirror adjustment switch can oxidise quite badly. My drivers side one is fine, but passenger side one needs a got hard push & a wiggle to get it to move.
You can clean the up apparently if you take the door cards off....
Central locking fault could be a tired pump.
Cool. I dont mind taking the Dorr Cars off, Done the G60 ones more than id like to have!! :lol:
Any difference in taking off the VR doors? How do you clean the contacts?
Cheers
I get the same problem, I find that constantly switching the "L" and "R" mirror push buttons sorts it out... Its a botch I know but water alwats drips on the mirror switch and the electric windows switches...
Is this alright in 'Problems' Brian?
NO! PUT IT BACK WHERE IT WAS!!!!! :lol:
Only kidding,
I thought i put it there in the first place!!! :oops:
Cheers
Shamelessly plagiarised from the CCA web site.....
(basically just says use some contact cleaner! And not sure if the US interior is early/late???)
FAQ/Tech Tip Detail:
Repairing Power Mirrors
Updated: 28-Dec-99
Author: Edwin Torres
Answer:
Problem: On my late 93 VR6, both power
sidemirrors will not function. I get a clicking sound when I depress the
power buttons. I checked the fuse and it's OK. Anyone have an idea at what gives?
Well thanks to Brendan, a.k.a. G60 racer, I solved this one simply and
beautifully. If followed properly it should work. Procedure is as follows:
1. On drivers side door, remove leather or faux-pas leather strip on door
handle with small screwdriver by prying gently from both sides.
2. Remove 2 screws holding door handle in place and remove entire handle assembly.
3. Disengage wire connector plug on rear.
4. Turn entire assembly around and gently pry off the small circuit board
behind the mirror positioning buttons.
5. You will then find the culprit. My boards copper contacts had become
oxidized! Proceed to clean these carefully with a good contact cleaner.
Follow chosen products instructions exactly!
6. Proceed to reassemble all using reverse procedures and voila! It worked!
Oh yea, you try this at your own risk and I cannot be
held responsible for damages incurred on your own vehicle. (legal
nomenclature :( )
Ddi you ever get your crystal repeaters? 8)
No, but just saw an ad for Volksbits in a mag yesterday which jogged my memory - ordering them today...
