spoier 0 Posted June 9, 2003 Hi All, I'm thinking about buying a Corrado (haven't decided on the G60 or VR6 yet) and I will do a compression check on whatever car I look at, but was wondering what the numbers should be. I know the important bit is less than 10% variation between cyls but a ballpark figure would be good... I searched the archives and found this for the G60: 116-174psi But I can't find the value for the VR6. Is the compression check procedure the same for other EFI cars (pull fuel pump fuse, run until car dies, then pull all plugs and check each cyl with wide open throttle). Is the fuel pump fuse clearly marked? Now to dig up some information on common rust areas.... Thanks! Skye Quote Share this post Link to post Share on other sites
Kevin Bacon 5 Posted June 9, 2003 Not sure on the compression figures of the VR but it's CR is 10:1, so figures around 180+ should be about right....I think! Ask Vince at Stealth Racing, he'll know for sure. The only place I've seen Corrados rust is around the driver's side repeater and on the front driver's arch lip. The passenger side doesn't seem to rot! You can get small amount behind the rear number plate trim where it clips into the metal work. Other than that, Corrados seem to fend off rust quite well. Kev 94 VR6 Quote Share this post Link to post Share on other sites
vr6storm 0 Posted June 9, 2003 kevhaywire said: The only place I've seen Corrados rust is around the driver's side repeater and on the front driver's arch lip. The passenger side doesn't seem to rot! You can get small amount behind the rear number plate trim where it clips into the metal work. Other than that, Corrados seem to fend off rust quite well. Kev 94 VR6 spot on there kev..........don't know :? how its never the n/s wing that rusts round the repeater Quote Share this post Link to post Share on other sites
Bournemouth James 0 Posted June 9, 2003 i went to view a g60 the other day, k reg, black, 116k, it was up for £3200 it had rust on all four arches and the sills, very unushall My 16v is a 1990 and and has no rust or any signs of rust anywhere Quote Share this post Link to post Share on other sites
