don
central locking
hello
the driver side central locking is not working, checked the pump-ok, checked lilttle mechanism inside the door - ok, checked the door handle- ok, all of the central locking works fine except the driver side, it works ok if u use the passenger side to lock and unlock, just in the process of checking the wiring through the door, any solutions?
thank you. :roll:
