BeavisJem 0 Posted January 14, 2005 A BIG THUMBS UP FOR DARREN AT G-WERKS Just had chip, pulley, boost return and full service and i have got a real beast of a car. Pulls hard all throught the rev range. Sat at 70 all the way home and was getting around 32 Mpg :) (Thats with some nice little bursts.) Without the chip and pulley and service i got 21 mpg on the way to G-werks :( Me very :) Had a great day cheers Beavisjem Quote Share this post Link to post Share on other sites
GazzaG60 0 Posted January 14, 2005 the MFA works from a predeturmined calculation. any changes to fueling/injector size wont be reflected by the MFA. dont trust it. what you have now is more timing more boost =more fuel Quote Share this post Link to post Share on other sites
BeavisJem 0 Posted January 14, 2005 Fair enough, it was overfueling before i took it down to g-werks so in a strange way ia getting better fuel economy. Quote Share this post Link to post Share on other sites
Majik 0 Posted January 14, 2005 what chip and pulley did you get? Quote Share this post Link to post Share on other sites
BeavisJem 0 Posted January 14, 2005 68mm and sns chip Quote Share this post Link to post Share on other sites
Supercharged 2 Posted January 14, 2005 BeavisJem, Nice one 8) Quote Share this post Link to post Share on other sites
Jim 2 Posted January 14, 2005 Alas the MFA lies through its teeth. I quite contentedly smile to myself on the motorway when I see I am knocking on 35MPG but if at absolute best I can only get about 400 miles from a full tank of the go juice (and thats a 15 gallon tank) i'm clearly getting only 26MPG. I didnt realise the MFA had preset variables so this explains the huge discrepancy. Quote Share this post Link to post Share on other sites
GazzaG60 0 Posted January 14, 2005 mine reads 12 all the time at the moment but i bet my bottom dollar that it reads different if i disconnect the battery and reconnect. SNS chips rule. not much more to say on that. mine manages to snap the engine mount and the top bolt yesterday anyway. Quote Share this post Link to post Share on other sites
Supercharged 2 Posted January 14, 2005 mine reads 12 all the time at the moment but i bet my bottom dollar that it reads different if i disconnect the battery and reconnect. I doubt that would make a difference, sounds like you have a leak in the pipe that feeds the MFA... Quote Share this post Link to post Share on other sites
stevemac 0 Posted January 14, 2005 mine reads 12 all the time at the moment but i bet my bottom dollar that it reads different if i disconnect the battery and reconnect. I doubt that would make a difference, sounds like you have a leak in the pipe that feeds the MFA... I doubt it will be that simple - leaking vacuum pipe will cause the MFA to over-read, 99.9mpg is the usual. Sounds more like a partially blocked pipe or electronic fault. Quote Share this post Link to post Share on other sites
Supercharged 2 Posted January 15, 2005 I doubt it will be that simple - leaking vacuum pipe will cause the MFA to over-read, 99.9mpg is the usual. Sounds more like a partially blocked pipe or electronic fault. I dunno, one of mine actually came off and the MFA started reading 13MPG the whole journey which I assumed was getting from atmosphere pressure Quote Share this post Link to post Share on other sites
stevemac 0 Posted January 15, 2005 There is only 1 pipe that feeds the MFA .. :roll: You mean a vacuum leak somewhere else in the system ? Quote Share this post Link to post Share on other sites
