oxfordpaul
How do you remove lower windscreen trim?
Hi, I want to clean my engine bay and scuttle area in particular. Problem is, can't remove the plastic trim along the bottom of windscreen. It's in 3 bits but feels like i'm gonna break it if i pull too hard - i think it's just clipped in. Ha anyone else done this successfully?
Had two windscreens fitted, neither came with new lower trims, the originals were put back on. They are normally held on by clips, but sounds like some are bonded back on after a windscreen change, making them difficult to remove without breaking.
My windscreen is a replacement and the fitter used what I presume to be the strongest glue the world has ever known.
From memory I think there should be a couple of screws, one at either end and probably a shed load of bonding if mine is anything to go by.
