Neil L.
Corrado lights..
As im a new c owner, could anyone tell me the lights sequence. I have a 94' VR6. Press once for sidelights? Press twice for main beam? Whats the standard headlight position(non mainbeam)? Cheers!
Main beam is controlled by the left hand indicator stalk, not the two position switch on the dash. You were correct on the sequence though, once for sidelights, twice for dipped headlights. Indicator stalk toggles high beam on/off and should be indicated by a blue light on the dash.
