ghee60
Number Plate Lights
broken wire or dodgy earth? Check for power at the bulbs and trace back from there... ;)
Usual breakage points are by the bootlid hinges ;)
mine weren't working and it turned out to be a broken wire in the light housing... raise the spoiler to help access and unscrew the body coloured plate and clear lens to check the connections in there. There is a wire between the bulbs that goes over a raised part of the lens - this is the wire that had broken on mine... fixed with a quick bit of solder 8)
