DaveStorm 0 Posted February 20, 2005 Ok guys here's the problem. I turn the key in the ignition and engine fires up first time as always, however the head unit is becoming very temperamental. Sometimes it switches on with the turn of the key, sometimes it doesn't. Only way to make sure it works is to turn the key slightly whilst the engine is running, but even then it may switch itself off at any time, but usually when driving along. All very strange, anyone any ideas? Quote Share this post Link to post Share on other sites
Jim 2 Posted February 20, 2005 I think thats the ignition switch on the fritz mate.. Quote Share this post Link to post Share on other sites
DaveStorm 0 Posted February 20, 2005 That was quick Jim, cheers! Ok I'll get that changed assuming it not too difficult a job. :wink: Quote Share this post Link to post Share on other sites
Jim 2 Posted February 20, 2005 http://the-corrado.net/how-to/index.php ... 95dcb370e4 :D Quote Share this post Link to post Share on other sites
NG 0 Posted February 21, 2005 It also depends on what head unit you are running, cos the new alpine range requires a direct feed from the battery NG Quote Share this post Link to post Share on other sites
Kevin Bacon 5 Posted February 21, 2005 It also depends on what head unit you are running, cos the new alpine range requires a direct feed from the battery NG Only if you're running the internal amp ("Power IC" in the primary menu) to drive the speakers. If you're amping the speakers there is no need to give the Alpine a direct feed. Quote Share this post Link to post Share on other sites
Furkz 0 Posted February 21, 2005 ded ignition switch mine did this too when i 1st bought it Quote Share this post Link to post Share on other sites
Ady_G 0 Posted February 22, 2005 Think this has just happened to mine as well, definately the red wire from the ignition giving no power when the electrics turned on. Not got time to change the ignition switch at the moment, also a few minor back and chest injuries mean I don't fancy lying upside down with my head under the sterring column. As my Alpine is connected to the battery anyway I was going to wire the ignition wire from the head unit to a the other permanently live wire from the standard stereo loom. I'm assuming that once the face plate is off the head unit it will draw no power, and everything else seems to work so i can survive with out a properly functioning ignition swith for a couple of weeks. Cheers Ady Quote Share this post Link to post Share on other sites
