jsites
ABS speed sensor removal replacement
Can anyone describe the safest way to remove and replace the rear speed sensor (ABS?) from a 91 Corrado? I could use a diagram of the rear hub assembly as the whole thing needs to be replaced. mailto:[email protected] Thanks!
Do you mean the cage or the actual sensor? I've got pics of the various bits (rear only) on a VR if that's any help?
Which model of '91 Corrado is it?
IIRC 1.8 16v's didn't have ABS.
Think it may have been an option on G60's.
Good point- it is a g60. New car for me- actually is my son's -replacing the whoole passenger rear assembly due to a slide in the snow against the curb. Easy car to work on but this has me stumped.
Not sure which parts you are wanting pics of mate? What don't you get....? The cage fits on the inside of the hub, it's just press on, and the sensor fits through from the back of the carrier(?) and sits just above it. This is on a VR again. It's pretty easy to change it all once the hub/disk is off.
