Supercharged Junkie
Bosch Relays
Hi
Am after a couple Bosch relays which are:
Bosch 0 332 019 151
Bosch 0 332 209 151
Can`t find anywhere that sells these relays, Can i use normal spotlight type relays or are these special relays
Any help
Ian
Cheers m8 if you could have a look for us
Although i think there just standard 5pin SR-2 relays, Got myself a S2000 starter switch and following the instructions on Oichan`s site
It said to use these relays
Maybe this will help :-
0332 019 151 = 5 pin fuel pump relay
0332 209 151 = 5 pin starter relay
Unfortunately, we stock neither. :(
