Roger Blassberg 0 Posted April 11, 2005 The side trim, (rubbing strip) section in front of the driver's door was loose whilst I was waxing the paintwork, so I pulld it off completely to save losing it. The adhesive strips are still stuck fast to the wing. Does anyone have a recommendation on how to remove these without damaging the paint, and on what to use to fix the trim back on? Best wishes RB Quote Share this post Link to post Share on other sites
dan 0 Posted April 11, 2005 Use 'white spirits' (won't effect the paintwork) & elbow grease. Allow the white spirit to soak into the old tape & it will come off a bit at a time. You will have to reapply the white spirit after each rubbing Stick the strip back onto the car with a general purpose double sided tape Quote Share this post Link to post Share on other sites
2cc 0 Posted April 11, 2005 Roger, yes. Guys, an even better product than White Spirit is: "Sticky Stuff Remover" Made by MYKAL. Comes in 250ml. Definitely find it in Focus and probably in similar stores. Quote Share this post Link to post Share on other sites
yellowdfp 0 Posted May 8, 2005 Mmmm - Meths: no good, White Spirit: no good, Label Remover Spray: no good, 3-in-1 oil: no good .... oh well, last resort ... Cellulose Thinners!: wow success. Now I know what you are thinking - is he mad - thinners will take the paint off! Well that's what I thought too but, even with much rubbing, no paint seemed to come off - perhaps because it's metalic and the laquer protects? I think they would ruin flat paints? Still needed quite some effort even using the thinners... after pulling the strip off, used plastic scrapper to remove as much of foam as possible then thinners on rag to soften remaing adhasive followed be dry rag to take off. T-cut and polish to finish off. Quote Share this post Link to post Share on other sites
Walesy 0 Posted May 9, 2005 AutoGlym's tar and glue remover does a pretty good job too. Quote Share this post Link to post Share on other sites
