Rollyrob 0 Posted April 14, 2005 Was wondering if anyone knew if the later modle C's indicator and wiper stalks would fit on my 1991 G60. Also does anyone know where i can get hold of some late type speedo pins the orange type Quote Share this post Link to post Share on other sites
Guest Posted April 14, 2005 Woody has fitted the later stalks, might be worth dropping him a pm, think he had to change the hazard light switch too Quote Share this post Link to post Share on other sites
Jim 1 Posted April 14, 2005 Yeah.. in short its a simply swap over, plug and play jobbie :) As Andy says, you do need the later hazard light switch too cause its a lot bigger :) Quote Share this post Link to post Share on other sites
JBOB 0 Posted April 14, 2005 Ive got late spec ones on my '90 Valver, I didnt change them but from what i can see you need to change the hazard button as andy665 says. Ive also got the cruse control buttons but i dont know if that came with all late spec cars. Quote Share this post Link to post Share on other sites
Jim 1 Posted April 14, 2005 Nope. Cruise wasn't common over here at all. Quote Share this post Link to post Share on other sites
daves16v 1 Posted April 14, 2005 I think Bally has them on his too. Quote Share this post Link to post Share on other sites
Red=Fast 0 Posted April 14, 2005 I actually just did it yesterday! You need the plastic surround from the later stalks and the hazzard light (its a part of the later stalks) as well. Everything just swaps right over same plugs and everything. Super easy swap if you could get a hold of a set. I will post some pictures up this weekend of them and my new roll cage after its installed. =] Quote Share this post Link to post Share on other sites
Bally 0 Posted April 15, 2005 I think Bally has them on his too. Yeap I do.. & with the early hazard switch :wink: Quote Share this post Link to post Share on other sites
biggrim 0 Posted April 15, 2005 You don't need to fit the later surround when you fit the late stalks to an early car. Quote Share this post Link to post Share on other sites
24V Renshaw 0 Posted April 15, 2005 I have a late type MFA stalk if anyone need one. £10 Jay Quote Share this post Link to post Share on other sites
Red=Fast 0 Posted April 15, 2005 You don't need to fit the later surround when you fit the late stalks to an early car. I know you at least need the top piece because the hazard light is much larger on the late stalks. I know the part number differs on the bottom cover on the late stalks from the early ones. I just used the late top and bottom piece and the late stalks. Everything worked out fine. Quote Share this post Link to post Share on other sites
Henny 0 Posted April 15, 2005 on the other question, the needles do indeed just swap over too, but I've yet to find anywhere which sells just the needles, so you'll probably end up having to butcher a set of late clocks to get the needles... Dunno if any other VWs used similar needles that could be used though... probably worth checking your local scrap yard for anything similar... 8) Quote Share this post Link to post Share on other sites
dubster82 0 Posted April 15, 2005 or alternatively... paint the needles. i was very very happy with my red painted needles. looked ace. :) Quote Share this post Link to post Share on other sites
Guest Posted April 16, 2005 click the link below and have alook at picys.. Did i kinda how to Quote Share this post Link to post Share on other sites
Rollyrob 0 Posted April 16, 2005 G60Dub clicked on the link but could not find anything about the Stalks ???? Quote Share this post Link to post Share on other sites
jamesmilsome 0 Posted April 17, 2005 With the risk of sounding stupid what benifit does the later stalk give? I've got a 90 g60 so is it worth bothering with? Quote Share this post Link to post Share on other sites
Rollyrob 0 Posted April 17, 2005 they dont have any benifit i just think they look neater. Quote Share this post Link to post Share on other sites
Guest Posted April 25, 2005 Rollyrob, there are pics on one of the pages Quote Share this post Link to post Share on other sites
woody 0 Posted April 27, 2005 The later stalks i have came out of a golf. The only difference with these are that the MFA cable is not as long and it required me to splice into and then heatshrink up the old cable (only four cables colour to colour). I had to buy the surround from Mr Steeler which comes in three parts. 1 hour job to do the whole thing. Golf bits should be easier to get then C bits. Quote Share this post Link to post Share on other sites
