WONGA
Dodgy rev counter
I have just bought a 2.0 16v rado and the rev counter is playing up is this a common fault and how do I fix it?
steve
Is this when you start the car, when it's idling or when you're cruising at a steady speed? If it's when you're driving, I wouldn't worry about it :-)
Check the coil connections first,
(green wire),it might be the actual
instrument that's faulty,try tapping
the cluster next time it happens,
may also be a dodgy contact on the
back of the cluster.
