jamesmilsome
merc wheels on g60 - help needed
Hi,
I want to fit merc wheels 5 x 112 onto my g60.
What options do I have. I know i can fit vr6 running gear and buy adapters but that sounds like a nightmare.
also they are et 35 and with spacers i would have et 15 i guess. What issues would I have as they are 8 j all round.
cheers
It's not posible...
You can't get 5by112 to 4by100 adapters and even if you had 5by100, the offset would be way out...
The only option here is to change to 5by112 hubs and discs (Audi)
it is possible to run merc wheels but you will need to convert to 5x100 (vr fitment) first... 8j should work fine
sounds like a bugger to do really. Fancied the lorinser wheels on the edition38 forum. recon they would look good. any idea what it may cost to replace g60 with vr running gear?
If you draw a 4x100 pattern with 5x112 you'll see that 1 bolt hole clashes with another where ever you try to offset them.....with 5x100 you can go right in-between the other holes.
