kevin
ETKA help
could someone check what the difference is in these two part numbers
> 535 919 042A
> 535 919 042E
they are both vdo's
many thanks
regards kevin
A is for Engine numbers starting with GB and PG
E is for Engine numbers starting with PG and KR
Apparently.
Apparently.
thank mate they are both clocks i have bought for a g60 but both give different readings and are slightly different,is the above the only known difference.
regards kevin
