Timo.
Advanced timing G60
Its a question for anyone who's got rather aggresive timing on their G60.
I finally checked the timing on my Dad's G60. We've only had the thing nearly a year. I knew for the previous owner that it was set a little more aggresive than standard.
Anyway, in checking through the peep hole at the flywheel I could not see the mark at all. So I un did the dizzy base at turn until I could see it. (AT 2500, with temp sensor disconnected it should bang in the middle, right?)
So I guessing it was quite ahead of standard.
I was just wondering, those who have it a few degrees more advanced if you can still see the mark? I just wondered how advanced the timing had be set.
The car seems to be a bit smoother and the idle is now spot on and its still going like a train :lol:
CHeers, sorry for the warble on
Simon
Just did the timing on mine today, and yes, I too, despite having used a timing light with adjustable advance setting couldn't find the timing mark (even though I painted a nice bright white :lol:). By turning the dizzy, i then found it, noticed a higher idle, which I corrected by closing the idle screw again, then took the Rado out for a good spin, and well chuffed with the result. Left the timing set to 6° BTDC, though.
More aggressive timing settings will be counterbalanced by the ECU, which retards the timing depending on the knock sensor signal and, of course what fuel you use.
Tempest
Yeh, I was thinking having it set at 6 degrees BTDC was the safe option. I certainly hasn't made it any slower or not that I can notice.
I'm just wondering how may degrees it takes to hide the timing mark out of site!? Just out of curiousity.
T.
Only a few, can't remember I how many degrees each tooth on the flywheel represents.
Tempest
