potatonet
NO OVERHEATING ANYMORE
so my car doesnt overheat anymore, sticks at 165 F flat, with my race thermostat and fan switch.... however, racing people up hills makes it overheat slightly, and consume water... it also consumes a little water on a daily basis... have to refill every week.
Check around the thermostat housing for a leak. Sounds exactly like mine, that started weeping after replacing thermostat.
ok thanks I will check that out, my fan also doesnt turn on, unless on defrost, replaced the 3 relays and the fan thermoswitch. would the little yellow one by the valve cover, the after run switch also control whether it turns on or off?
