Heardy
VAG-COM which program?
Can someone tell me which program i need for my OBD 2 interface lead i've looked on the rosstech website and there seem's to be a lot more version's than there was before when i downloaded it :? .Any ideas ?
Thanks alot Jason
I borrowed a lead from a mate and used the one to match the lead. HEX-COM can or something.
Gavin
That's what i'm not sure about Gavin.I've got a X-ONE OBD 2 lead and i'm not sure which one i need.
There's two main program versions on the VAG-COM site because the 3.04 (iirc) version is the LAST that works with the old opto-isolated leads. The newer leads use faster technology and the newer software releases take advantage of that.
Your Corrado VR6 will work perfectly fine with the old VAG-COM and any old OBD-compatible lead. The C VR6 is an OBD1 ECU. The connector may be OBD2, but it's all OBD1 protocol.
