COR VR
Sunroof trouble (yawn)
The sunroof on my rado has been working fine until a month ago when I locked the car using the total closure from fully open. As the panel slides out to 3/4 of the way closed it seems to jump up a few mm, thus scratching the paint (bugger!). I can counteract this by holding the panel down, but it ain't the most practical way. Has anyone had a similar problem?
yup, welcome to the broken sunroof group...
If you use the search there's LOTS of info on here about the sunroof and how to fix this problem... 8)
I'll lock this up now... 8)
Just like to add, it's the water plate guide that's worn causing the scratching. They wear on the nearside first for some reason.
A lack of grease and frequent use of the tilt mode causes the wear.
Odd how the exact same components in the MK3 and Passat never break though.
