Roger Blassberg
Handbrake
Do you mean the grip handle? or the flat plastic cover thing? either way...
grip can be tricky, had this problem a few weeks back, basically if you look that the underneirth of the handle right at the bottom theres a little 'nipple'. you might have to pull the leather cover out of the way to see it properly. If you push that nipple in with the end of a screwdriver and pull on the grip it sould come out. Its fiddly to get the screwdriver in the right place, but when you do the grip slides off easily, so if you're having to pull and pull its probably not in the right place! once thats off you can slide the flat plastic guard off the shaft of the handbrake and you're good to go!
