dtjames 0 Posted May 15, 2005 My battery was flat when I came back from holidays and now my alarm does not work at all! When I press the alarm key I hear a very faint bleeping sound if I listen carefully at the alarm unit. I know my remote control battery is fine so what and how do I fix this? Obviously now I have to use a key to open the doors too. :shock: Quote Share this post Link to post Share on other sites
h100vw 0 Posted May 17, 2005 Did you jump start the car or remove the battery to charge it? Either way I would disconnect it for a couple of minutes and then reconnect. Lots of alarms are not happy when the battery drains slowly. Gavin Quote Share this post Link to post Share on other sites
dazzyvr6 0 Posted May 17, 2005 Did you jump start the car or remove the battery to charge it? Either way I would disconnect it for a couple of minutes and then reconnect. Lots of alarms are not happy when the battery drains slowly. Gavin thats what i have to do to mine,as i got a big power drain on my car at the moment,full battery only lasts 2 days then its flat :? Quote Share this post Link to post Share on other sites
dtjames 0 Posted May 17, 2005 I will try that tmrw cheers guys for ths update replies. 8) Quote Share this post Link to post Share on other sites
