Republic Of Mancunia
95 VR6 Problems
Hi all, I've got a couple of problems with my VR and hope someone can point me in the right direction.
Recently I fitted a new Alpine stereo to the car, whilst doing this I inadvertently ran the battery down to the extent that it wouldn't start. After a good few hours on charge it started fine and I took it out for a good long run.
A few days later I noticed.......
Problem 1
My spoiler isn't going up all the way when I hit 60. It is only going up 1/2 of the way and doesn't return properly when I come to a stop. When I use the button on the dash it takes 4 or 5 attempts to get it to go up all the way and the same to put it down.
Problem 2
When I started the car yesterday my ABS light came on and stayed on. I tested the brakes and it skidded. Tried again and forgot to put my foot on the clutch so the car stalled. When I restarted it the ABS light went off, tried the brakes again and the ABS kicked in. Happy Days...... or so I thought. Went out in it again today and the ABS light is back on and no ABS.
Have I done something dodgy with the wiring? Or fried something when it was on charge? Or is this just a coincidence?
Is there anything I can check before I take it to a garage and for them to turn around and say 2k please!!!
Spoiler sounds like it's getting stiff (oooerrr), as for the ABS the only sensible way to tell what's up with it is to scan the error codes. Most likely it's a problem with one of the front wheel sensors. They are often intermittent like you describe.
