HiAsAKite 0 Posted May 26, 2005 Before anyone says this has been done to death..I've searched through every topic I could find under sunroof AND problem or sunroof AND broken to no joy..... Problem is this.. it slides ok it tilts up ok but when trying to tilt down.. it slides back instead of tilting until jamming against the rear sunroof opening... I managed to shut it by holding it with my hands in the forward position until it had tilted back to stop it sliding.... I'm guessing something locks to stop it sliding back whilst its open, and this is no longer 'functional'... Closest thread I could find is this one: http://the-corrado.net/.archive/forum/viewtopic. ... of+problem But it doesn't actually explain what the original problem was.. Has anyone had this before/can help? Thanks all, :( Quote Share this post Link to post Share on other sites
Kevin Bacon 5 Posted May 27, 2005 When the roof is next up, pull the panel liner off and slide it into the roof cavity. Now, pulse the switch to lower it gradually again and look at what's going on with the water plate guides (intricate steel millings) as the roof tries to drop down. What SHOULD happen is the pin inside each water plate guide follows it's route, dropping the roof in the process, and then start the sliding process. From what you've described, it sounds like the water plate guides are moving back instead of dropping.....could be that one of the pins is jammed in it's channel? Quote Share this post Link to post Share on other sites
HiAsAKite 0 Posted May 27, 2005 Thanks Kev.. I'll have a look Al. Quote Share this post Link to post Share on other sites
