Phil.C 0 Posted June 14, 2005 Can anyone tell me the best way to 'clean' the isv? Is it easy to check if this thing is working properly? Quote Share this post Link to post Share on other sites
Walesy 0 Posted June 14, 2005 http://the-corrado.net/.archive/forum/search.php?mode=results welcome to the forum dude...use the search....theres loads of info on here... type " isv and test " in....should help you out. Quote Share this post Link to post Share on other sites
CazzaVR 0 Posted June 14, 2005 Hi, try a search- this has been discussed loads! As well as the ISV, check the pipes leading into it. My first 16v developed a terrible idle all because there was a small hole in one of these pipes. 5 minute job to sort it. HTH. Quote Share this post Link to post Share on other sites
