reaper1_3 0 Posted July 11, 2005 been offered this setup below was wondering if it was any good and how much it was worth? i am only looking at running speakers including a set in the doors and a set of 6x9,s not really sure if i need all of this if not any advice? do i need 2 3 or 4 channel?? Jet Sound 300 Watt Model JS 4090G MOS-FET TECH 2x150 Watt, Bridgeable 1x300 Watt Low or high level input Gain control Full or Sub range cross over filter Power protection Pro sound 120 Watt 4 channel Low or high level input Gain control 4ch or 2ch switch Startech Suppressor Model HYN-18 High quality noise suppressor Isolation transformer Cabels and accessories 2x Distribution blocks 1x in-line fuse block 5m High Quality RCA lead 5m RCA lead 5m power lead 5mm Quote Share this post Link to post Share on other sites
billinjah 0 Posted July 11, 2005 you need 4 channel, that set up is very low quality, imho you would be better offgetting a nice headunit and running all your speakers from that Quote Share this post Link to post Share on other sites
stevemac 0 Posted July 11, 2005 The Pro-Sound 4 channel amp will be okay for the front/rear speakers - I have a similar one in my car. I assume the other will be for a sub ? If so, try to get one with a slightly bigger power handling. Quote Share this post Link to post Share on other sites
reaper1_3 0 Posted July 12, 2005 thanks guys would i be better then getting a 4 channel amp as i intend to upgrade later with a sub in the boot obviously...! Quote Share this post Link to post Share on other sites
stevemac 0 Posted July 12, 2005 In your list - there appear to be 2 seperate amps. The 4 channel Pro-Sound one should be okay for the front & rear speakers but won't power the sub. If you're fitting a sub - get the highest output, 2 channel amp that you can afford. This can then be "bridged" to supply a single channel to the sub. I have a Pro-Sound 4x120w amp in my car - powering VIBE component front speakers & the biggest 6x9's your likely to see, in my MDF parcel shelf. I can vouch for the sound quality - sounds great ! Quote Share this post Link to post Share on other sites
Bobby 0 Posted July 13, 2005 Get an alpine 4 channel that runs a decent rms.Unless you have people in the back all the time i would go for a component setu up up front door speaker for mids some dash tweets and then leave the 6*9's out and have a sub for the rear. Runn the sub on a class d mono amp and that should sound pretty sweet when you sat in the front of the car. Quote Share this post Link to post Share on other sites
reaper1_3 0 Posted July 15, 2005 Thanks all good advice as always will have to give this some thought have already got the front speakers and 6 x9s in an mdf shelf so will probably go for a 4 channel amp and see how it sounds!! :D Quote Share this post Link to post Share on other sites
