Rpmayne 0 Posted July 13, 2005 I'm looking to buy some cheap alloys for the missus's 12v corsa as it needs 4 new tyres anyway and the bicycle tyres offer little grip when pushed with the mighty 3-cylinder power plant. :lol: It will hopefully help with the cornering / braking anyway. I take it the PCD is the same at 100mm but the VW offset seems to be ET35 and some of the wheels being fitted to corsa's are ET49. Would the VW ones fit? This is just to get abit more choice. Not really sure what the offset relates to. Cheers. Quote Share this post Link to post Share on other sites
chrishill 0 Posted July 13, 2005 IIRC Vauxhall's offsets are notoriously high, meaning your choice is limited. VW ones would fit, but they'd stick out from under the arches. http://www.tyres-online.co.uk/techinfo/alloy.asp Quote Share this post Link to post Share on other sites
Rpmayne 0 Posted July 13, 2005 Thanks for the info. Quote Share this post Link to post Share on other sites
biggrim 0 Posted July 13, 2005 I think the spigot ring (or hole) is smaller on vauxhall too. I remember fitting my dad's 17's to the G and had to take little blue spigot reducers off so they'd fit. Quote Share this post Link to post Share on other sites
BigTartanJudge 0 Posted July 13, 2005 Hi, The stud pattern is the same, 4 x 100PCD but standard Vauxhall offset is ET49 and VW is ET25 or 38. Centre bore fitment on VW is 57.1 mm wheras Vauxhall centre bore is 56.5 mm. You would need to get the centre bore changed by having the wheel centre bores machined on CNC / lathe etc by a professional. I had this done to get some MiM Vauxhall fitment alloys onto my old G60 but also has problems with inside of wheels fouling on the G60 calipers so I used 5mm spacers and no probs then. Cheers Quote Share this post Link to post Share on other sites
Rpmayne 0 Posted July 14, 2005 Thanks for that, sounding abit involved for my liking so think I'll stick to Vauxhall wheels on the crazy corsa. Quote Share this post Link to post Share on other sites
bcstudent 0 Posted July 14, 2005 Migweb: http://www.migweb.co.uk/ ....for all your Vauxhall forum needs. Quote Share this post Link to post Share on other sites
