TREVR6 0 Posted July 17, 2005 Hello, My vr6 unit is sitting higher on the n/s than the o/s by about an inch. I've recently changed the front mount because it was weeping black goo!! I'm just about to order new rear mounts too, to try and sort my current problem but cant understand why if the rear mount is knackered it would be sitting HIGHER?? Surely the engine would drop if anything! Thought maybe the o/s had dropped but no it's definitely the n/s that's up because it has dented my bonnet :x Could the mount have come adrift and be pushing the engine up?? It all looks OK. Anyone had similar problems? New mounts has to sort the problem doesn't it? Or could there be something else? Any info gratefully received, Thanks Trevr6 My bonnet though Grrrrrrrrrr :mad: Quote Share this post Link to post Share on other sites
Joe M 0 Posted July 17, 2005 Its normal for them to sit high at one side. The dent probably came from movement in your old knackered mount. Quote Share this post Link to post Share on other sites
TREVR6 0 Posted July 17, 2005 Yea it does seem to move a lot more than it used to and the new front mount didn't seem to change that. I'll put new rears on too and hopfully it should be back to how it was. Anyone know how bad pearl gray fades, Had a pannel re-sprayed, Did it match up well, (just incase the bonnet needs painting) Cheers Quote Share this post Link to post Share on other sites
Kevin Bacon 5 Posted July 18, 2005 The engine should be higher on the Offside than the nearside and tilt down at the front also. Quote Share this post Link to post Share on other sites
