cookie 1.8 16 valver
Samco on a 1.8 16v
Hi Guys
I now need a new set of hoses as it's got a leak...somewhere (very tiny) and the bottom hose is softer then bazil brush. Is there anywhere that does them as Samco say they are not available or anybody got any good suggestions ?
Thanks
Cookie
Hi Guys
Thanks
Cookie
5 of the 7 hoses in the mk2 16v GTI Samco set go on, only leaving the header tank to head and heat exchanger hoses, you can buy a couple of metres of 8mm bore samco to do the rad to expansion tank run.
Will cost from 120 quid to about 160/170 if you try to do all the lengths of hose from the golf kit plus individual lengths and elbows, probably still cheaper than a VAG rubber set though!
David.
