B5UBA
temp
hi corrado team,
on me 1.8 16v i want to know what the coolant temp should be running at,
mine runs just below 110....when its around there the car dont feel comfortable.
can anybody help
does sound a bit high right enough......though to be honest the guages aren't exactly totally accurate.....mine indicates 100+ deg C when it is in fact only 92-ish...........as long as the fans come on you should be ok but i would get it checked out by a garage for "peace of mind"
Thats fine for a 1.8 16V although would check on a few things to be sure:
- Check that the one way valve fitted at bulkhead on coolant pipes (two of them go into bulkhead and connect to exchanger) has not packed up...
- Check anti - freeze is right amount (50/50)
- Check fans come on like Roddy says....
- Check thermostat is working ok
- Try back flushing the rad
But I do remember in summer mine used to stick at around 105degC - came down in winter...
If you have made the above checks then you have nothing to worry about as the guage is not accurate - what is more important is that the light doesnt come on the dashboard *:)
Scott
nice one boys,ill get them checked out.tell u what once me coolant light did flash,but that was a cold start in the morning,switched the car off/on then it was fine.is that cause of sensor fault?i did top up but only about half a pint r less.
