redcorrado 0 Posted August 5, 2005 my leads are due for replace,ment ,but the ones fitted to the car one of the leads closest the battery has a lead atta\ced to the lead then it goes to the engine somehwere ,does this make sense ?? lol any way the new lead i bought havent got this ,i think its called pick up lead ,does it need this . ps car is 1993 2.0 16v Quote Share this post Link to post Share on other sites
Supercharged 2 Posted August 6, 2005 Yep, you need it mate - it basically does the job of a hall sender and sends a signal to the ECU... Does it look like it will come off the old lead?? Quote Share this post Link to post Share on other sites
redcorrado 0 Posted August 6, 2005 not sure as ive given them to the garage ,whos gona look at them on monday,stupid euro car parts . Is that the correct name pick up lead ? Just incase i need to rder another set Quote Share this post Link to post Share on other sites
Supercharged 2 Posted August 6, 2005 redcorrado, think you just need this if it's a 9a engine... Impulse sender - 051 905 381 Quote Share this post Link to post Share on other sites
redcorrado 0 Posted August 6, 2005 oh right ,what does that do. Quote Share this post Link to post Share on other sites
Supercharged 2 Posted August 6, 2005 It's the extra lead that clips on... check with yer dealer tho before ordering... Quote Share this post Link to post Share on other sites
gradeAfailure 0 Posted August 7, 2005 You can actually just unscrew the end of the plug lead and slide off the ring sender, then unscrew the end of the new lead and slide it on, then screw the end of the lead back on... Just done this to Laura's, so can confirm this is correct... BTW, it should go on the lead for No.1 cylinder... hth! Quote Share this post Link to post Share on other sites
redcorrado 0 Posted August 9, 2005 Cant i get a set of leads with this attached,seems a bit daft to take brand new leads apart. Quote Share this post Link to post Share on other sites
gradeAfailure 0 Posted August 9, 2005 AFAIK, no you can't... It really does only take 5 mins though! Quote Share this post Link to post Share on other sites
