Blinky16v 0 Posted August 6, 2005 Hi Guys, Been searching through this site and took the leap to change my switch colours to red. Instructions on here were spot on but I cannot for the life of me find how to get the Sunroof switch bulb out (I have the assembly out and apart but I can't get the $%#$ rocker switch detached so I can get to the bulb). Plus, how do you get the door mirror swith off? I noticed some of you guys have done this mod if i have missed a page already on this could someone point me to it? Cheers in advance guys... Quote Share this post Link to post Share on other sites
Supercharged 2 Posted August 6, 2005 I've done the roof switch... it does come apart just keep trying! Quote Share this post Link to post Share on other sites
Supercharged 2 Posted August 6, 2005 Ah, sorry - forgetr that - Mine was an early one... What sort is yours (there are 2 types of later one) Quote Share this post Link to post Share on other sites
flusted 0 Posted August 6, 2005 can some1 post a link for how to do this? Quote Share this post Link to post Share on other sites
Blinky16v 0 Posted August 8, 2005 Hi Again, Managed to get the switch off the sunroof switch and wired it in, only to find it doesn't light up. On thing I found was the negative side of the LED appeared to plug into thin air...? Anyone who's done this mod know where the LED earths to? Cheers Quote Share this post Link to post Share on other sites
Blinky16v 0 Posted August 8, 2005 Hi Flusted, For the LED change I used, among others, this web link which tells you what to do, its quite basic but should give you an idea. http://www.corradoclubmd.com/technical/ ... ights.html Hope this helps Quote Share this post Link to post Share on other sites
Blinky16v 0 Posted August 9, 2005 Anyone who's done this have any ideas on this? I have reached a stopper here and have no idea what to do next.... Quote Share this post Link to post Share on other sites
Supercharged 2 Posted August 9, 2005 Blinky16v, which switch is it, late rocker switch?? Quote Share this post Link to post Share on other sites
Blinky16v 0 Posted August 10, 2005 Its the later Rocker Switch type m8 Quote Share this post Link to post Share on other sites
Blinky16v 0 Posted August 18, 2005 BUMP Tried again last night to get the LED working in the roof switch but still no joy! It seems to have nowhere to earth to! Has no one done this mod at all? The roof switch is the late rocker type switch... Cheers Quote Share this post Link to post Share on other sites
gradeAfailure 0 Posted August 18, 2005 If there's a pin on the switch plug numbered 31 then trace where this goes to in the switch and earth to there - I know on the dash switches that pin 31 is always earth... I'll be doing a late-spec led change to red/blue soon so will attempt to take some pix if I remember, and do a how-to... Quote Share this post Link to post Share on other sites
24V Renshaw 0 Posted August 18, 2005 Be careful as some of the lights in the Corrado switches are 12v lamps rather than LEDs. So you need to get a tiny 12v lamp instead of an LED. I did it to mine (before I fitted all the MK4 stuff which lights up red anyway) and that is what I found. Hope that helps Jay Quote Share this post Link to post Share on other sites
Supercharged 2 Posted August 18, 2005 ...Or get a 12V LED... Quote Share this post Link to post Share on other sites
Blinky16v 0 Posted August 19, 2005 Thumbs up guys thanks for the help. I have a 12v LED and Lamp and the only issue was finding where it earthed to. I'll take a look for pin 31. :) G60Renshaw: Did you fit the Golf Mk IV sun roof switch and light unit to your C m8? Quote Share this post Link to post Share on other sites
