Kevin Bacon
VR6 big bore throttle
I *think* the resistance I measured is 3250 Ohms.... 3.25 on the 2000 setting. Measured the spare I have and that was 4.0
That sounds ok for a cold engine, that equates to 10-15 Degrees C
I'll try Toms ISV next week.
Inside the idle silencer thingie, there's a bit of foam filter, seems like it's quite black/ solid to me, is this normal? How freely should air flow through the silencer?
Think I'll try changing the stat and stat housing maybe.
Oh and I may have found access to a VAGCOM - what do I do with it :)
I'll try and do the basic settings. Anything else?
Jeez, just tore out the foam filter for the ISV silencer, and it is idling fine.
Shouldn't be a problem without the filter should it?
