welton 0 Posted August 17, 2005 Hello all Sounds stupid but I cant get my old door handle out - I have removed the screw from the inside of the door but I cant get the front out. I did my old '90 G60 and from memory there was no other screws, Should it just clip out ? passenger handle - '94 vr6 Thanks Quote Share this post Link to post Share on other sites
chrishill 0 Posted August 17, 2005 it should just slide forwards a few mm then the back (lock end) should come out of the bodywork allowing you to get the front out. - edit - dont forget to disconnect the cable! maybe its a bit short and isnt allowing the handle the freedom of movement it needs? Quote Share this post Link to post Share on other sites
welton 0 Posted August 17, 2005 Yep the lock end is out, cable disconnected but I cannot pull the front bit out - I have pulled it really hard so much that the door is bending with it Reckon it is a cheapie handle and a bad fit Brute force it is..... Quote Share this post Link to post Share on other sites
coolrado 0 Posted August 17, 2005 if you have the back completely out try rotating it by 90 degrees and it should come out. as far as i know nobody makes "cheapy" handles for them so it should be a normal one Quote Share this post Link to post Share on other sites
Supercharged 2 Posted August 17, 2005 Previous owner may have fitted armoured door plates?? Quote Share this post Link to post Share on other sites
welton 0 Posted August 17, 2005 Thanks for all ur help lads The cable had been screwed to part of the window frame so the lock part of the handle came out a few cm but not quite enough to let the other end out. Looks like a cowboy fitted the window eh!!!!! All sorted now tho ta Quote Share this post Link to post Share on other sites
