Taggart 0 Posted September 1, 2005 I recently replaced the full beam indicator LED and the full beam appears to have stopped working (although the LED now comes on). When I flick the stalk the headlights go out and the sidelights go on. I have an uprated loom (not sure if it's Gavs), and the full beam worked perfectly well before I took my dash apart. Any ideas? Quote Share this post Link to post Share on other sites
cheesy 0 Posted September 1, 2005 At a guess the fuse has blown on the loom or the relay has died chris Quote Share this post Link to post Share on other sites
Taggart 0 Posted September 2, 2005 But it worked perfectly well before I replaced the broken LED. Quote Share this post Link to post Share on other sites
Taggart 0 Posted September 2, 2005 The plot thickens, it's only the drivers side sidelight that comes on. Quote Share this post Link to post Share on other sites
h100vw 0 Posted September 2, 2005 Mine look like this ..... Quote Share this post Link to post Share on other sites
Kevin Bacon 5 Posted September 2, 2005 And what a fine peice of automotive engineering it is too :lol: I lost my beams too once and it turned out to be the exposed inline fuses that were crudded up. Wrap them in tape is my advice. Quote Share this post Link to post Share on other sites
h100vw 0 Posted September 2, 2005 OT There will be a number of these fine items available on Sunday at e38. Get them while they are hot. :mrgreen: Gavin Quote Share this post Link to post Share on other sites
Taggart 0 Posted September 3, 2005 They look pretty much like that Gav. Quote Share this post Link to post Share on other sites
h100vw 0 Posted September 3, 2005 PM sent with my number. The only light on the front that works is a sidelight? Very strange. To start, prior to calling me if possible, I would check all the lighting fuses, in the fusebox and the loom. Swap the 2 relays in the loom around and see if anything changes. Try reconnecting the std wirng back onto the drivers side headlight and test the lights. Also, you do have the ign switched on don't you. Gavin Quote Share this post Link to post Share on other sites
