marksvr6 0 Posted July 31, 2003 guys, Quick and easy. my drivers window has fell out of the track and I need to remove the doorcard to sort it out. is it the same as the mk2 golfs or what do I need to do to get it off? Quote Share this post Link to post Share on other sites
biggrim 0 Posted July 31, 2003 Exactly the same | think. Just be careful of the electric window wiring. 8) Good luck mate Quote Share this post Link to post Share on other sites
marksvr6 0 Posted July 31, 2003 cheers m8, have it wedged up at the min but its bloody pissing it down here!!!!!! Quote Share this post Link to post Share on other sites
macca 0 Posted July 31, 2003 Just taken mine off, the only thing not so obvious is the screw under the speaker grill. Quote Share this post Link to post Share on other sites
biggrim 0 Posted July 31, 2003 Didn't have one of them on mine but that might be because it's the late interior in an early car. Sorry mate. Where is the screw under the grill anyway? Quote Share this post Link to post Share on other sites
macca 0 Posted July 31, 2003 Mines a 93 Vr, if you pop the speaker grill from the door card there is a recessed screw front edge. Quote Share this post Link to post Share on other sites
marksvr6 0 Posted August 1, 2003 AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAGGGGGGGGGGGGGHHHHHH 2 screws in open part. 1 in closed. take out lockpin,door card off. 1 billion looms to disconnect. motors screwed. put it all back together (with a heavy piece of wood jammed up to keep the window shut. Gadddddddddammmmmmmmmmmn it 100,000 miles on sunday avo. reverse into a bollard on sunday night. drivers window falls out on tuesday. blow out last wed. F************** ELL MATE!!!! Quote Share this post Link to post Share on other sites
willmason 0 Posted August 4, 2003 I have a window mechanism out of a 95 corrado £20 + p&p if your interested Quote Share this post Link to post Share on other sites
marksvr6 0 Posted August 5, 2003 I have a window mechanism out of a 95 corrado £20 + p&p if your interested Cheers, but Igot sorted yesterday for 30 quid. damn sight better than VAG's quote of 180 +VAT+fitting. barstewards!!!!!!! Quote Share this post Link to post Share on other sites
G60Jet 1 Posted August 5, 2003 Believe it or not VW have a special tool for removing the door cards off a C, its like a pickle fork. and is used to remove the card from the bottem clips. Quote Share this post Link to post Share on other sites
marksvr6 0 Posted August 5, 2003 Believe it or not VW have a special tool for removing the door cards off a C, its like a pickle fork. and is used to remove the card from the bottem clips. and I bet they use it every time!!!! :wink: Quote Share this post Link to post Share on other sites
2cc 0 Posted August 7, 2003 why? the clips are just rests for the card to sit on - doesn't need a tool Quote Share this post Link to post Share on other sites
dazzyvr6 0 Posted August 7, 2003 Mines a 93 Vr, if you pop the speaker grill from the door card there is a recessed screw front edge. no wonder i could'nt get mine off :lol: Quote Share this post Link to post Share on other sites
