B DUB 0 Posted September 10, 2005 HI TO U ALL .JUST WANTED TO KNOW IF ANY OF U NO HOW TO AJUST THE BEAM ON THESE AS MINE ARE LIGHTING UP THE TREES AT THE MOMENT?? :?: Quote Share this post Link to post Share on other sites
Andy665 0 Posted September 10, 2005 You need to buy the adjusters - I know mine did not come with them pre-fitted, don't know the EKTA number but still available at the dealers or you could take them off your old lights Quote Share this post Link to post Share on other sites
B DUB 0 Posted September 10, 2005 Cheers mate got to get them done cant c a thing. :scrambleup: Quote Share this post Link to post Share on other sites
GIXXERUK 0 Posted September 10, 2005 are they inpro ? did you get them off ebay ? they look superb on your red c were they an easy fit? Quote Share this post Link to post Share on other sites
Supercharged 2 Posted September 10, 2005 Where did you buy them from - they should be adjusted/setup after coming into the country... Quote Share this post Link to post Share on other sites
GIXXERUK 0 Posted September 10, 2005 did you take it to an mot centre to set up the h/light alignment ? if so what did they charge ya Quote Share this post Link to post Share on other sites
LicklePaulie 0 Posted September 11, 2005 To clarify: the In.Pros for some unknown reason come without any height adjusters - as stated earlier you must either remove them from your original headlight units and install or (my own experience) go to the stealers and buy some cos the plastic locknuts become brittle with age and won't come out in one piece :mad: . They are still available but stealers are having trouble locating them at short notice Quote Share this post Link to post Share on other sites
woody 0 Posted September 11, 2005 mot place charged me a fiver to set mine up as plane kept landing near me. Quote Share this post Link to post Share on other sites
Waz 0 Posted September 11, 2005 Where did you buy them from - they should be adjusted/setup after coming into the country... i'v seen them in venom motor sport abt £180 + vat i think Quote Share this post Link to post Share on other sites
GIXXERUK 0 Posted September 11, 2005 does it matter if they are lhd or rhd ? Quote Share this post Link to post Share on other sites
sciroccotune 0 Posted September 11, 2005 Could the front glass be removed and the original corrado glass fitted in its place? Quote Share this post Link to post Share on other sites
Supercharged 2 Posted September 11, 2005 The glass is completly clear so the difference between lhd and rhd is just the direction of the bulbs/reflectors, hence the need to adjust them Quote Share this post Link to post Share on other sites
Andy665 0 Posted September 11, 2005 Yes, it is feasible to replace the clear front with the original glass but you'd have completely uselss lights. The In-Pros are a reflector design and therefore will only work effectively with the clear glass front on them. The lights are easily convertable to either RHD or LHD format - takes about 5 mins per side Quote Share this post Link to post Share on other sites
GIXXERUK 0 Posted September 11, 2005 so are they all lhd ? awesome gti do them for £225 and they are on ebay for £225 inc p&p Quote Share this post Link to post Share on other sites
Andy665 0 Posted September 11, 2005 Mine where amongst the first batch into the UK and came with beam pattern set for LHD but I believe that the latest ones are coming through set-up for RHD, the instructions should tell you how to convert them if you need to Quote Share this post Link to post Share on other sites
Supercharged 2 Posted September 11, 2005 I think they leave the factory set up for LHD but the UK distributer or retailer should be setting them up for RHD unless they are selling them and clearly stating that they are LHD. Quote Share this post Link to post Share on other sites
Supercharged Junkie 0 Posted September 11, 2005 Anyone figured out how to rewire these lights so they main beam stays on when you put the full beam on ? Because full beam is shite on its own and unless you have an HID conversion done theres no real point in the main beam going off. Quote Share this post Link to post Share on other sites
GIXXERUK 0 Posted September 11, 2005 Andy665, Supercharged, cheers for the info Quote Share this post Link to post Share on other sites
GIXXERUK 0 Posted September 11, 2005 Supercharged Junkie, it does that on the standard lights, mainbeam on and the dipped goes off but not if you flash iirc Quote Share this post Link to post Share on other sites
Supercharged Junkie 0 Posted September 11, 2005 Are you sure, pretty sure mine didn`t, althou would explain why i can`t figure out what makes the main beam go off :? Quote Share this post Link to post Share on other sites
GIXXERUK 0 Posted September 11, 2005 i'll double check later but i'm pretty sure tbh Quote Share this post Link to post Share on other sites
LicklePaulie 0 Posted September 11, 2005 The later models do NOT require setting up to RHD professionally - they have a lever behind the front reflector plate which requires switching from left- to right-hand drive. Instructions included and it literally takes two minutes per side. Supercharged Junkie, GIXXER is correct - main beam does switch off when main beam is applied unless flashing (in courteous fashion of course :wink: ). What you desire can be done but the wiring mod would be in the car body rather than the headlight unit Quote Share this post Link to post Share on other sites
