gsbellew 0 Posted September 20, 2005 Just looking to see if there is anything obvious I should check first or if its normal, but my central locking pump (right hand side of the boot behing the carpet) runs on for about a minute after locking or unlocking the car, its like its not getting a signal to stop for a while, could it be a loose vaccum connection or where should I look first? I already tried searching the previous posts but did not find anything yet. Quote Share this post Link to post Share on other sites
h100vw 0 Posted September 20, 2005 Leaky pipe will cause this, if not sorted the pump will burn itself out. I had a Passat with no locking. Fitted a new one which ran and ran. I found a leak which then stopped the problem. Try checking the door shuts first. Gavin Quote Share this post Link to post Share on other sites
gsbellew 0 Posted September 20, 2005 Cheers for that, I'll try the conections and see if I can find anything. Should the boot un-lock with the central locking? Mine doesn't :? Quote Share this post Link to post Share on other sites
markmcie 0 Posted September 20, 2005 Hey Geroid, congrats on the new car. the boot should lock / unlock with the central locking if you have manually left the boot unlocked with the key. Quote Share this post Link to post Share on other sites
gibber 0 Posted September 20, 2005 Sound like thats where ya leak is, some where in the boot! I would take off the pipe that goes to ya boot (pump side)and block it to check and if ya pump runs fine then you will know! U do know the boot loch has 3 possitions, 1 unlock, 2 (quarter turn) lock with central locking 3 (half turn) lock with key only Cheers for that, I'll try the conections and see if I can find anything. Should the boot un-lock with the central locking? Mine doesn't :? Quote Share this post Link to post Share on other sites
gsbellew 0 Posted September 20, 2005 Hi Mark, Finally moved on from the Polo and followed the rest of ye to Corrados :lol: @ Gibber, thanks for that I'll have a look later, still don't have the boot lock complatly figured out, mine seems to have 3 positions, _ l and / if that makes any sense, I take it it should go more like _ l _ ? taking the lines to represent the angle that the key sits at, the boot opens with the ket at / but the key can not be withdrawn :? Quote Share this post Link to post Share on other sites
gsbellew 0 Posted September 21, 2005 Had a look last night, the central locking actuator in the boot seems to be stuck and is leaking, so that seems to be why the pump runs on for a while. Quote Share this post Link to post Share on other sites
