cubed 0 Posted September 28, 2005 got a little problem,have mentioned it on other threads but no clues as yet. my n/s front wheel is catching the arch no matter how much i lift the front end,funny cos the o/s is well clear of any contact. i know some of you guys run lower than me and wondered how youve got round the problem? as far as i can tell,everythings in order,however when the rain lets up i need to check my offsets. do i need to modify the arch liner or could it be somethin else? any advice is appreciated as usual! thanks Quote Share this post Link to post Share on other sites
stevemac 0 Posted September 28, 2005 Did you have the front camber re-aligned after you altered the suspension ? As you can see from my piccy below, mine's quite low & doesn't catch or rub anywhere since I had the camber set-up properly. Quote Share this post Link to post Share on other sites
Furkz 0 Posted September 28, 2005 what tyres and wheel sizes ahev u got also as steve states you can get ya camber adjusted 1 or 2 degrees negative to help although i think ur problem maybe your tyres /wheels/ size , ET etc Quote Share this post Link to post Share on other sites
Riley 0 Posted September 29, 2005 can you get a good pic of each side m8? but id be checking the et of your wheels first,and then get the camber etc checked out as the guys say. if you park on a good/flat surface a spirit level could give you a good idea :lol: or you should be able to tell just by looking. mines never caught either. Quote Share this post Link to post Share on other sites
cubed 0 Posted September 29, 2005 right had a look and the wheels are 7.5 x 17 on an et 37 offset,sending it in for tracking and camber tomorrow! think they may be a little wide? i,l sort a pic for tomorrow Quote Share this post Link to post Share on other sites
gsbellew 0 Posted September 29, 2005 I've 8 * 17's and no rubbing, so I would have thought 7.5 * 17's would be fine, what tyre size do you have? Quote Share this post Link to post Share on other sites
stevemac 0 Posted September 29, 2005 As a guide - mine are 7.5x17 rims with 205/40WR17 tyres. Used to rub like fcuk until I had the camber set-up properly. I've heard many people say that there's little or no front camber adjustment on Corrado's - complete rubbish, there's at least 5 degrees worth of adjustment on mine! Quote Share this post Link to post Share on other sites
cubed 0 Posted September 29, 2005 they,re 205/40/17s got it in for camber setting tomorrow. any recommendations on the degree? they,re quite reputable so they should know what to do.... i hope! Quote Share this post Link to post Share on other sites
cubed 0 Posted September 30, 2005 well just got my car back from a so called vw specialist they,ve cured my problem but in the process whilst playing with my coilovers, chewed up all the adjusting rings,theyve not covered five miles yet!!!! needless to say im extremley annoyed! any suggestions on a course of action? Quote Share this post Link to post Share on other sites
stevemac 0 Posted September 30, 2005 cubed, Take your car back to the garage & demand that they rectify any damage that they have caused. They shouldn't have touched the coilover height adjusting rings at all, in order to correct a camber problem. Quote Share this post Link to post Share on other sites
cubed 0 Posted October 1, 2005 ive done as you,ve recomemnded and the units are being replaced, they say my subframe is twisted slightly. so they compensated with the coilovers. rang this morning was polite,but assertive they,re getting it sorted monday they assured me my chassis is unharmed,but i dont know if its worth replacing that subframe?? could it be costly!! so camber cant be set to the degree i need cos of the subframe. Quote Share this post Link to post Share on other sites
stevemac 0 Posted October 1, 2005 I'd be interested to know how/where the subframe's twisted. Has the car been in an accident at some point ? Quote Share this post Link to post Share on other sites
cubed 0 Posted October 1, 2005 yeah i think so,ive known about it being bumped before for sometime,like i say the chassis straight all factory sealer is intact. get a feeling its been pushed out by a bump on the wheel. but its purley speculation! i,m going to have to look when the rain finally lets up!!! i,l replace it if need be as im planning on keeping it a long time! Quote Share this post Link to post Share on other sites
